Need help leveling out my jk! a quick fix??
ok here's the deal... i put a 2" rough country spacer lift on my jk, it is a 2.5" on the front and a 2" spacer on the rear, but its still an 1" or so low in the front?? i hate the saggin' look. could it be my winch pulling it down, rough country says it should level it out, but no luck! is there anything i can do to fix this?? a quick or cheep fix w/o putting a whole new suspension kit on! does anyone make a 3" spacer or something?? thanks for any help or advice!!!
can you do that?? has anyone on here done that, i did install the shock extenders that came w/ the kit.... i was thinking of adding another spacer, but didn't know if it would pose a problem or not?? any help or advise from someone that has done this would be great!!!
I have the 2.5" tf kit and after my steel bumper it became nose heavy. I added the .75" spacer on top with no problems since. almost a year now. I still have a little rake. I'd go with the 1" teraflex spacer for best results. After a while you springs will sag b/c of the weight.
so, since mine are already 2.5" in the front will it be ok and safe to add the 1" from teraflex on top?? is there anything i need to know before doing this?? this would be the cheapiest and fastest way to do it, just wont to make sure its safe??? the wifey drives it some too w/ the little ones! thanks guys!!!
