Need Help - Out of ideas
I posted a similar thread a week ago about a noise I was getting on my Jeep on acceleration and stopping. A clicking/popping sound. I have gone through every suspension compoent on my Jeep and tightened anything that was remotely loose. Found a couple of loose jam nuts which were fixed as well as a loose bolt on my drag link. Everything is tight. Also checked all u-joints on axle and driveshafts and they appear fine. No strange movements at all with any parts we looked at.
The one thing that I can narrow the noise down to is that it ONLY happens when it is below freezing outside. If its above 30 degrees, the noise is nowhere to be heard. So I need help is getting some ideas on what would cause this noise ONLY when it is below freezing. My build is in my sig....
I will add that I have NOT pulled my diff covers yet. Someone mentioned maybe I have water in the diff and it is freezing but the noise does not go away after driving for 20 minutes. I would think that if there was water in the diff, it would melt when the oil heats up. But honestly, This noise does not sound like anything in the diff...
Someone else suggested that maybe the frame end joint on my Rock Krawler arms are binding maybe due to the cold..?? I am lost....need help!
http://www.youtube.com/watch?v=au-taMlAl2U
I don't know why it would be cold related, but could it be coming from your driveshafts? Also have you tried lifting the vehicle on a rack and having someone drive it while you listen from underneath?
As we can tell, driveshafts (both 9 month old 1310 Costs shafts) seem to be fine. No play at all with and no noise coming from them when manualy attempting to move. I did try a simple put it in drive and hit both the gas and brake (to see if it was coming from engine) and the noise does not happen. Only happens when I move so it is somehow related to actual movement. I think maybe I will try to put it on jack stands and kick it into drive to see if the noise is there. If it is not, then I will definitley know it requires weight shifting and most likely a bushing or something. Lift isn't even a year old so hopefully not a bad joint somewhere..
Does it only happen when you go from rev to fwd and fwd to rev? Or does it continue doing it while driving? Stop and go traffic?
I also think its gonna be drive shaft related, do you have the shaft installed correctly? Joints in the correct order? As well ( it happens) do you have the correct shaft installed ( length, size)?
Is the shaft greaseable ( you have aftermarket ?) ? Have you greased it?
