Need Help Picking Bilsteins
I want to get a set of the Bilstein 5100s. Here is my problem.
Bought the 2010 JKU with a mystery lift installed.
I believe it is a "Zone Offroad" lift. I can't tell the height.
It's either a 3" lift or a 4" lift.
Obviously the bilsteins split the difference right around that mark for which set of shocks you should buy. Any suggestions on which I should go with or how I can confirm the lift height? I mean even if I knew what the original lift was supposed to be it could have settled right? So should I just go with the shorter set of bilsteins or no?
Any help is appreciated.
I suppose I could but this is the one job I was gonna let the shop do.... just because I have read about how much of a mfer the shocks are to remove at the top side. So if I don't have to remove it to find out I would prefer not to. Anyone else?
