Need help, rubbing sway bars
Old Jan 24, 2010 | 04:06 PM
Bosox5's Avatar
Veteran: Coast Guard
Default Need help, rubbing sway bars
Hey guys, so I installed a JKS front adjustable trackbar and TF Front lower flex arms last week and centered my axle and increased my caster and was well until I came up to a light to make a U-turn at full lock and got some scary vibes. I checked it out and it appears that I am rubbing both sway bars at full to near lock on each side. Ideas on what I should do? Thanks!
Old Jan 24, 2010 | 04:10 PM
mkjeep's Avatar
Swaybar links or control arms??? How much backspace is on your rims?
Old Jan 24, 2010 | 04:15 PM
Bosox5's Avatar
Not the links, the actual sway bar I believe. I have 5.0 BS
Old Jan 24, 2010 | 04:36 PM
Suffolk JK's Avatar
13.5" tire on a 5" BS, the problem is you are rubbing tire. Add washers to the turn stops or change your rims.
Old Jan 24, 2010 | 04:42 PM
Bosox5's Avatar
I have been running this setup for a year with no rubbing at all....Its when I installed my LCA's and front trackbar this all came to light
Old Jan 24, 2010 | 05:03 PM
Suffolk JK's Avatar
Do you know exactly where it's rubbing?
Old Jan 24, 2010 | 05:04 PM
Bosox5's Avatar
Yes, right on top of the sway bar on both sides.
Old Jan 24, 2010 | 05:06 PM
Bosox5's Avatar
I most definately would have noticed it, I turn full lock daily to park and its a very bad vibe I am getting now after the install.
Old Jan 24, 2010 | 05:10 PM
Suffolk JK's Avatar
The vibe is from the M/Ts rubbing on the swaybar correct?
At 12.5" width and 3.75" BS I'm damn close to rubbing, I can only imagine a 13.5" and 5" BS.
Old Jan 24, 2010 | 05:12 PM
Bosox5's Avatar
Yes sir, and it has never rubbed like this before until installed my LCA's and trackbar.
