Need help, squeak after regear
Old Apr 5, 2012 | 04:04 AM
Markdsv's Avatar
Default Need help, squeak after regear
I regeared to 513 a month ago and yesterday I noticed a squeak while driving, ok I need to open the window and listen carefully but there is a squeak. I am sure it is rotational as it is like screech......screech (like a cricket) and it does it when the diffs are warm....... it is strange though that what I break it is gone. Thought it might we a warped break disc but not sure why this suddenly should happen (haven't been wheeling since the regear). Definitely coming from the rear.
Also if I put the drive in neutral the squeak continues, touch the breaks (very light) and suddenly stops...... start squeaking again after a few 100m.........
Maybe it is a wheel bearing so I took the drive shaft out this afternoon and had a look at the bearings etc but all looks OK. I'll bet it is the pinion gear bearings, so maybe the garage need to do it all over again
Anything thoughts.....I hate squeaks.......especially as I know a squeak is wearing something, I don't want to get a total bearing failure (will justify my Dana 60 though :crazy eyes
Cheers
Mark
Old Apr 5, 2012 | 04:10 AM
crazyloggy's Avatar
Sound like this.
http://m.youtube.com/#/watch?desktop...e1AE7eOg&gl=US
Old Apr 5, 2012 | 04:32 AM
Markdsv's Avatar
Originally Posted by crazyloggy
Is this the correct link?
Old Apr 5, 2012 | 04:59 AM
crazyloggy's Avatar
Fixed it. My bad
http://www.youtube.com/watch?v=vame1AE7eOg
Old Apr 5, 2012 | 06:22 AM
Markdsv's Avatar
cheers, thanks again, don't think my axle is bent...I ran my jeep on the jack (carefully) and didn't hear a it........
Old Apr 7, 2012 | 04:31 AM
Markdsv's Avatar
Checked my regearing by taking out the drive shafts, the lot. Put all back together, guess what..........still making the squeaking sound. it is definitely coming from rotation and I think it is my right wheel, tried everything. The squeak comes only after driving a few miles and is quite loud a low speeds
Put the rear axle on stands and let the car run but no squeaking sound so it looks like it is only under load. Any thoughts, I am getting really annoyed.
Old Apr 8, 2012 | 11:16 AM
dkclimber's Avatar
I had the same thing. Drove me crazy for a month. Turns out I bent the dust shield on my rear brakes and it was coming into contact with the rotor just a little after the rotor heated up. Same symptoms, it would go away under braking.
I just bent it back a little and all has been good. Hope this helps for you!
