Need help with stuck Jam nuts
Old Jan 9, 2012 | 11:03 AM
mattgt5's Avatar
Default Need help with stuck Jam nuts
I bought some rear control arms on the forum and I need to adjsut them but the Jam nuts are stuck. need some advice on everyone's can't miss method for breakign loose a stuck jam nut. Thanks for the help
Old Jan 9, 2012 | 02:11 PM
Offroad's Avatar
Previous owner may have used loctite. If that's the case, then heat is the way to go.
Old Jan 9, 2012 | 02:14 PM
RedOffRoad's Avatar
before you try heat I would get a can of PB blaster first and see if its juts corrosion build up.
Old Jan 9, 2012 | 02:28 PM
qkrawler's Avatar
Try the pb blaster that's a miracle worker if nt then heats the way to go...
Old Jan 9, 2012 | 02:36 PM
jeep2007's Avatar
You can also try Aerokroil. We use it on stuck aircraft bolts and really works.
Old Jan 9, 2012 | 05:17 PM
tslewisz's Avatar
^^^^ that's the goods ^^^^
Old Jan 10, 2012 | 05:06 AM
mattgt5's Avatar
Where do you get that stuff? Thanks
Old Jan 10, 2012 | 05:33 AM
tslewisz's Avatar
I get mine from MidwayUSA. I first heard about it in benchrest shooting circles.
Old Jan 10, 2012 | 11:30 AM
SilverBolt's Avatar
Make sure they are not left hand threads.
Old Jan 10, 2012 | 11:33 AM
mattgt5's Avatar
Got that part covered. The threads on the arms are pretty big and easy to see which was is up. Thanks
