Need help with TF 2.5" lift
Ok everything was going fine untill I got to the relocation bracket for the track bar
When I put the bracket up into the factory bracket the holes are about 1/8" off with the bracket bottomed out
This is a known and common problem with the teraflex track bar relocation bracket. People have come up with different solutions from putting the bracket in a vise, to drilling the holes out a little bit.
I drilled the hole out a little bit on mine. Just enough to get the bolt through using my BFH. May not have been the best solution, but it worked for me in the time/frustration level I had.
Good luck, and if you search the threads you will find how others have dealt with this known problem.
