Need help with tires...
Old Mar 11, 2009 | 05:30 PM
Labrador's Avatar
Default Need help with tires...
Hey guys, will 33x12,5x17 (305 65R17) tires fit the stock rubi rims?
with 1,5" spidertrex spacers and 2" lift? Will they rub?
Thanks
Old Mar 11, 2009 | 05:55 PM
Labrador's Avatar
Anyone?
Old Mar 11, 2009 | 06:01 PM
sulldoggy's Avatar
Thanks
Don't see why not! I have 285/70/r17's..though I thought they were close to 33"
I could probably fit 35's...
Old Mar 11, 2009 | 06:13 PM
joneszj's Avatar
Shouldnt have any rubbing issues as long as you use the spacers
Old Mar 11, 2009 | 06:22 PM
Labrador's Avatar
Yeah, but will the fit on the rim? The tires won't be too wide for the rim?
Old Mar 11, 2009 | 06:37 PM
KSU_MAN_JK33's Avatar
I'm running the factory wheels with 33x12.5x17 with 1 1/2" spacers and no issues...should be good to go
Old Mar 11, 2009 | 06:47 PM
Stuka's Avatar
You will need spacers. Oh, and 305's arent 12.50's, they are 12" wide. 315 is a 12.50.
As for fitting the rims, they will fit. The center of the tire will wear faster than the outsides unless you get the air pressure just right. As the tire is having to be pinched quite a bit to fit.
