Need Lift Kit help.
Okay okay so i was gunna leave my jeep stock for a few months, but looking through the gallery photos just made me droll.
So i have a few questions.
I wanted a wider stance so i already purchased the 1 1/2" wheel spacers
i want this lift, 3.5 rubicon coil lift
http://www.northridge4x4.ca/proddetail.php?prod=RE-7142
but im wondering do i need shocks?
if so do i need them for both the front and back?
and as well as whats this steering stabilzer? do i need it?
and can i install this myself or should i get someone to do it for me?
thanks guys! really looking forward to the respones
You need shocks front and rear
Your factory steering stabilizer will work( not sure if this is what your asking
You can install it yourself. Use the write-ups on here for a 3in lift.( I suggest not installing the cam bolts though, you'd be better off getting adj front lowers and rear upper control arms. You have a 4 dr so you really won't need rear uppers until you change out the rear driveshaft for a double carden one. ) The front lower CA's would allow for castor adj, but you could always drive it and see how the handling is for you and whether or not you can deal with the handling before ordering some. I drove mine almost a year with 4in of lift and no adj control arms.
)You can install it yourself. Use the write-ups on here for a 3in lift.( I suggest not installing the cam bolts though, you'd be better off getting adj front lowers and rear upper control arms. You have a 4 dr so you really won't need rear uppers until you change out the rear driveshaft for a double carden one. ) The front lower CA's would allow for castor adj, but you could always drive it and see how the handling is for you and whether or not you can deal with the handling before ordering some. I drove mine almost a year with 4in of lift and no adj control arms.
