Need a little help with power guys...
well i have 2010 6speed, 2.5BB, with 35s. This is my first jeep and have only had it a few months and these are the only mods i have done. I plan on re-gearing within the next few months and am willing to take any suggestions on that. But in about a week i willing be making a drive that usually takes 12 hours. Right now my jeep cant even maintain 70 in 6th gear, is there anything i could put on there without re-gearing to help with this problem for now, just to add a little more highway speed?
Order a Superchips Flashpak. If you search Superchips you will find TONS of info about it. I'm in a similar situation where I will be regearing but prob not before I go on my trip and I decided on a Superchip.
No I'll be getting them shortly but I did a bunch of research and it seems the front lower arms are the way to go. I've already added a front adjustable trac bar and will be adding a rear one eventually as well. The trac bars are not a priority as the lift you and I have doesn't shift the axles out much and with my lift and I'm sure yours too come with a rear trac bar bracket to correct the geometry of the axle. But, I've been adding things as I can because I hope to get into a bigger lift and would like to chip away at the expense by adding some items as I go.
RIPPTECH
