Need Quick help please...Can't get axle shaft out
Old Dec 28, 2010 | 01:43 PM
NJKen's Avatar
Default Need Quick help please...Can't get axle shaft out
Ok, long story short U-Joint failure and needed to replace and upgrade axle shaft. Well I have everything apart but I can't get the front drivers side axle shaft to come out. My D30 is sleeved, could that be the reason why this isn't coming out? I am not getting it to budge at all
Old Dec 28, 2010 | 03:46 PM
JdTms11's Avatar
it really should just slide right out the unit bearing is the only thing that holds it in so as soon as you pop that off i just slides out. with the front end jacked up can you spin the shaft by hand?
Old Dec 28, 2010 | 03:57 PM
NJKen's Avatar
Yeah, I can spin it by hand but there is one spot where it gets tight.
Here is what I just tried:
As you might be able to see I took a tow strap and my scissor jack and tried pulling from the u-joint
Old Dec 28, 2010 | 04:58 PM
grady's Avatar
Default Axle shaft
Did you try tapping on it with a hammer when you had it under pressure with the jack and strap? Maybe a slide hammer?
Old Dec 28, 2010 | 06:12 PM
Jeter's Avatar
There ain't no tapping going to get it out. You gotta hit that thing hard.
Old Dec 28, 2010 | 06:14 PM
PainKiller's Avatar
a little heat might help
Old Dec 28, 2010 | 06:20 PM
NJKen's Avatar
Ok, well the Jeep beat me....
Once I took the dif cover off, attached to the ARB magnet was a piece of a tooth. So the gears are shot and when I looked in to see what was preventing the shaft from coming out I saw that the spines were all chewed up. So I am going to call the closest off road shop and the Dealership to see who is going to give me a better deal on putting new gears in and replacing the shaft.
Thanks for all your help everyone!
Old Dec 28, 2010 | 06:39 PM
NH-JK's Avatar
Sorry to hear that. Good luck with the gears.
Old Dec 29, 2010 | 06:40 AM
NJKen's Avatar
Ok the shop is booked until the 10th, can I just pull the front drive shaft and drive around like that?
Old Dec 29, 2010 | 07:07 AM
wayoflife's Avatar
JK-Forum Founder
bummer about you gears - your r&p will still spin with the drive shaft off. remove the axle shafts, plug up your tubes and you should be good to go.
