Need some advice
Old May 9, 2012 | 08:08 PM
sick jk's Avatar
Default Need some advice
Hi. I just had my upper and lower ball joints replaced from a off road shop that is one of our sponsers here. I have only put like 30 miles on it since the work was done. I just noticed today a puddle of gear oil coming from the axle joint. I called the shop and they said that they don't pull the shaft to replace ball joints. But all the write ups and videos I have seen say to pull the shafts. I think they are just trying to not take responsibility for it. Do you guys think it is related to the work. Or is it just coincidence that there is a major leak right after the work? Give me your advice please. Thanks
Old May 9, 2012 | 09:01 PM
sick jk's Avatar
Anyone have an opinion on this.
Old May 9, 2012 | 09:08 PM
ronjenx's Avatar
I guess it's possible they may have a ball joint tool that could work around the axle shafts being in place.
If they do, just letting the shafts rest in the axle tubes may disturb the seal enough to make it start leaking.
Old May 9, 2012 | 09:29 PM
sick jk's Avatar
Yeah. That's what i was thinking. Another question. How hard is it to change a axle seal? Is it $300 hard.
Old May 9, 2012 | 09:41 PM
ronjenx's Avatar
On the front axle, the shafts and differential have to come out.
It's also common for the new seals to leak. Sometimes the seal is damaged when the axle shaft is pushed through it.
Old May 10, 2012 | 09:46 AM
sick jk's Avatar
Bump for more info please
Old May 10, 2012 | 10:07 AM
sick jk's Avatar
I know this. I just wish this didn't happen. Going to have to figure it out.
Old May 10, 2012 | 10:18 AM
Edge Hawk's Avatar
30 miles after leaving the shop... sounds like someone didn't do something right.
Old May 10, 2012 | 11:35 AM
sick jk's Avatar
Problem is that I have no proof. They are telling me that they didn't remove my axles to do the ball joints.
Old May 10, 2012 | 12:18 PM
IZZNICE's Avatar
No bueno.....
