Need some guidance
Old Mar 26, 2013 | 08:40 AM
JLsJK's Avatar
Default Need some guidance
I have 2011 2 door 4.88s running 35s. I've cut the fenders and pinch seam. Changed suspension bolts to grade 8 bolts, also running 19/59 coils with longer shocks and front sway bar.
It rides really good, but wondering if it were your jeep(not changing any of the above components) what would you, or could I add too.
Leave it alone??
What height do people start adding trackbar brackets? Would they help?
I got about 2 inches of lift from the coils. Have no rubbing anywhere. Just wandering if there's anything out there that will help the driving experience. My biggest complaint with ride is steering correction.
Thanks
Old Mar 26, 2013 | 09:02 AM
kjeeper10's Avatar
Vet Army
2.5 lift will shift the axles about 3/8 so you should have nothing to worry about.
As long as the jeep drives good, I would leave it be.
Edit: more caster will help steering correction.
- adjustable lowers are what most run
- AEV drop brackets do the same
Make sure you are toe'd in 1/16-1/8
Old Mar 26, 2013 | 06:32 PM
JLsJK's Avatar
Thanks zzzzzx
