Need some more help
When I brake I am pulling to the right and the harder I brake the worse it is. ANy ideas? I am no mechanic but am trying to do everything myself these days. Thanks in advance for any help.
A few options. Clogged brake line.. kinked brake line.. or if you got brakes done the spring inside could have not been installed. Warped rotors could be the problem too.
Originally Posted by afdude87
Unless one tire is extremely low on pressure or was swapped out from a bald tire to a new spare and the other wasn't, wont be tires
Been really busy thanks for the replies. I have a 07X never had a brake job, run 265/70r/17's mickey thompson mtz only have 25k on my jeep. I do notice some pull not much when driving if I let the wheel go. It pulls way more when I brake. Sometimes if I brake unexpectedly and forget it can throw me in the other lane. No grinding noises at all. seems to be the right front brake I think. It seems to be where the pull comes from. No squeaky brakes dont do that much off roading. May be the tire I never rotated them I know stupid but i work overseas and dont spend that much time stae side so it sorta wasa forgotton issue.
I think I ansewred everyones questions I will check the brakes rotor and pads.
