need some opinions on best setup for 37's or 38's
Hi guys, I have a stock 2010 JKU auto 4wd and I'm getting ready to take the plunge into the money pit
Here is what I'm thinking and I would love some feedback
Either
BDS 4.5 long arm kit or Teraflex 4" long arm kit
Toyo open country MT 37x14.50x15
or
BDS 6.5 long arm... the 6" Teraflex is a significant jump in price
Toyo open country MT 38x15.50x16
I probably won't have money right away to do much else but I would plan on getting new drive shafts, 5:13 or 5:38 gears axle sleeve and gussets for the front axle, flat fenders... for now I'll chop the stock fenders
I'd love hear from people with similar setups what worked and what doesn't... Can i get away with just getting the lift, tires and wheels or would I wait until I have the $$ to do it all at once
Are there any issues with going to 38's vs 37's?
Thanks guys
Either
or
Thanks guys
Well you can get away with a 4 inch lift, flat fenders and 3.50bs or less wheels to run 37. I would look into a Dana 44 front if you don't have a rubicon. The endless amount of ways to run 37s.
As far as wheels go what would you recommend for a 3.5 BS. The lowest i could find were Rock Crawlers with a 3.75 BS. I wanna keep the cost of wheels around $150 or less each.
I wanna run the biggest widest wheel i can without having to get new axles.
Originally Posted by jbrodsky
Thanks for the info. i would love to get a new axle but i dont have the extra coin right now to swing it. I was thinking about adding a axle sleeve and gussets for the front.
Since it is your plan to get the flat fenders anyway,,, I would research the lowest lift you can get away with, with the best flex. If you know you're not going over 38's, and you're going to flatten out the fenders,then you don't want to go too tall. The lower the center of gravity the better! I see posts on here about stock jeep suspensions with 37's. I would not recommend this, as the flex just isn't there. I know I havent been the biggest help, but just my 2 cents. Good luck making your jeep yours!
