Need Traction Aid
I have a 2012 Sport without a rear Trac Lok. I would like to add a rear traction device that won't break the bank and still be able to handle 33" tires and have good streetability. Most of my wheeling will be forrest roads, farm fields, and deep snow. Considering adding a Trac Lok or Tru Trak. Any suggestions?
Detroit TrueTrac. Much better than the factory limited that uses clutches. From your stated use, this would be my first choice.
Next step up would be a Detroit Locker. This is a full locker, with some street driveability quirks. Excellent offroad, though.
And after that you are looking at thousand dollar selectables. ARB would be my top pick here.
Maybe consider doing front and rear?
Originally Posted by Tonka_yellow
I wouldn't lock a Dana 30 on 33s unless you build the Dana 30
No offense, but have you run a truetrack with 33s on a D30?
I wheeled the heck out of my old ZJ with a dual true tracks with 31" tires, 4.56 gears, and a V8 with almost 300lbsft torque. This was a Low pinion D30 so power was to the coast side. 4.56 is important as it means a smaller pinion. I had no problems.
In other words, under a dog engine, HPD30, with a limited slip, he'll have little to no problems.
