need to trim my LoD mid width
So I just upgraded to 37's, ordered a rock krawler 3.5 lift, flat fenders, and 1" body lift.
Haven't yet installed the lift (currently on an OME lift) but it looks like I will have to trim my mid-width signature series bumper for clearance.
Has anyone else done this, or have pics of a trimmed LoD? I hate to have to cut it.
unless you just wanted a change in lift, you would fit 37's fine with the flat fenders, ome lift and the 1" bl for sure. just need to pm plannman for the correct bumpstop length. but back to your question on the lod. your backspacing on the wheels will most likely determin if you need to cut or not. i would run a minimum of 4 on bs pref 3.5 for your 37's. if it does hit i would sell the bumper and replace it unless you can weld and cut it yourself. you will prob be cheaper in the long run. or you could always switch out the wheels if there not the right bs.
my bs is 3.5 right now (thats including my spacers) but still have contact on wheel crank and compression.
I don't really want to cut it, but don't like the depth of the stubby LoD.
Still on the fence I suppose
