Negative affects from wheel spacers?
Your first two sentences are a little hard to understand. Can you clarify exactly what you mean.
Anyway, if the tire's point of contact with the road is moved outward, the load on the bearings and ball joints will be increased. It doesn't matter if it's because of different backspacing or installation of a spacer/adapter.
Well go to discount tire or les schwab tire center and ask them to install some and find out answer from them too. Ohh yeah and tire factory said same thing and my brother is friends with local owner of store and he normally does stuff for us that he won't do for others. Oh did I mention said owner is a pro rock racer and a buggy builder. So yeah I go with the engineers and experts over internet "gurus" no disrespect meant to anyone but don't try to change my opinion as I was just offering a point of view
Not sure I follow, a spacer and factory wheel and a wheel with a 4.5" bs would have the tire in the same place in space equal distance from the hub and the ball joints. The weight would still be hanging out there in the same place.
No. The mounted point is cantilevered out 1.5" more. If I was in person I could draw it up the way the engineers did but it does make a lot of since when you can finally see what I mean. I think smashboogie or one of the other sponsers agrees on this statement
