New Bilstein SS + Dominion Relo = Alignment Issues?
I just finished installing the Dominion OffRoad Steering Stabilizer relo bracket and a new Bilstein SS. Install went fine and no issues. Went on a 20 mile test drive and notice that the rig now pulls left a bit. Not much but noticeable enough that I think something is off. Anybody else experience this? Could it be the location of the clamp on the tie rod that needs to be moved? The instructions have you installing the shock tube end at the tie rod clamp (reverse of stock) but also has a note that some older JK's requires you to flip it end to end. Could this be my issue?
TIA
TIA
I had the same thing when I installed the Bilstein SS with no other changes and I have seen a couple of other threads saying the same thing. The Bilstein SS is charged so that it wants to be extended, that gives you your pull tho the left. In time it will break in and the pull will go away. Anyway, that's what happened with mine. I think it is a good unit. CM
