New door hinge install
Old Sep 22, 2013 | 08:38 AM
mrbigwrench's Avatar
Default New door hinge install
So after watching my outer door hinges turn to shite with bubbling, flaking paint, I did some research and found out they're still using the cheap white metal for outer door hinges. Jeeps in the warmer climates are probably not affected by this, but where they are using salt and crap on the roads in the winter are the JKs that are having this problem.
So I ordered the Kentrol stainless steel black powder-coated hinges (both halves), they should be here this week. My question is, who knows the easy way to align the body hinge so the doors close properly? I have the unpainted spots where the old body hinges mounted, but I'm almost certain my new ones aren't going to be an exact fit. Any hints would be welcome! Thanks!
Old Sep 22, 2013 | 08:48 AM
v8zracer260z's Avatar
Veteran: Marine Corp
Measure where the old hinges were and mount the new ones in the same location. Jeep doors are easy to align as the bolts are outside. Once you have the gap ok you can open the door and adjust the hinge in and out so the door sits flush. The doors are fairly light (compared to a conventional car door) but a spare body makes this a breeze.
Old Sep 22, 2013 | 08:56 AM
roscoj's Avatar
I took mine off to repaint them. I just traced them on the door with a grease pen and reinstalled them I didn't have any fitment issues doing it this way.
Old Sep 22, 2013 | 09:00 AM
EHarris's Avatar
JK-Forum Ambassador
Originally Posted by mrbigwrench
So after watching my outer door hinges turn to shite with bubbling, flaking paint, I did some research and found out they're still using the cheap white metal for outer door hinges. Jeeps in the warmer climates are probably not affected by this, but where they are using salt and crap on the roads in the winter are the JKs that are having this problem. So I ordered the Kentrol stainless steel black powder-coated hinges (both halves), they should be here this week. My question is, who knows the easy way to align the body hinge so the doors close properly? I have the unpainted spots where the old body hinges mounted, but I'm almost certain my new ones aren't going to be an exact fit. Any hints would be welcome! Thanks!
Can you provide a link where you purchased these. My hindges have been repainted 3 times now from the dealer. They just start rusting again each time after about 6 months. I do live by the beach but feel that a quality paint job should not rust them up. Especially that quickly and especially after 3 times!
Not sure what I can do about the area where next to windshield (where light brackets are installed). This area is now showing rust again after 3 times repainted.
Any other advice would be great. Thanks everyone.
Old Sep 22, 2013 | 09:03 AM
Thanks for the tips. Just to clarify, the outer hinge is non adjustable, only the body half is, correct? I look at my old ones and the slots are only on the body half.
Old Sep 22, 2013 | 09:07 AM
Kentrolinc.com is the site. They make lots of stainless Jeep accessories
Old Sep 22, 2013 | 09:11 AM
Wow, so you're having the same issue in S Calif?? I was told its mainly where they're salting the roads.
Don't worry, it's not actually rust, just corrosion of the 'pot metal' that looks like hell.
Old Sep 22, 2013 | 09:34 AM
Sorry, I should've said they're avail. at Quadratec also
Old Sep 22, 2013 | 09:41 AM
EHarris's Avatar
JK-Forum Ambassador
Wow, so you're having the same issue in S Calif?? I was told its mainly where they're salting the roads. Don't worry, it's not actually rust, just corrosion of the 'pot metal' that looks like hell.
Well my hindges did do the corrosion but the windshield bracket and the top of the hindges are def rust. They seem to happen more in my opinion on 2007-2010 and certain colors too.
Old Sep 22, 2013 | 03:47 PM
There's supposed to be a lemon in every batch, maybe you found it.
