New front bumper.
Old Mar 18, 2011 | 07:41 AM
RAZDJK09's Avatar
Default New front bumper.
I am in the process of putting on a Body Armor front bumper that eliminates the use of the factory driving lights, I have 2 questions. What have you guys done with the factory wiring from those lights. Did you cut the wiring off or just tuck it in some where out of the way and leave it. Other thing is, I purchased (for now) 2 Hella offroad lights, I was thinking of using the factory wiring from the factory driving lights to power the Hella lights that I bought. Is this a good idea or not. Thanks
Old Mar 18, 2011 | 07:48 AM
JK-Ford's Avatar
Unplug the harness. Don't Cut! Save it for future. The Helas have to be the same rating or less to use the OEM circuit. You can install a new harness and use the OEM switch.
Old Mar 18, 2011 | 07:57 AM
bksnyder2's Avatar
I recently Installed a new Smity Bilt front bumper and wired two hella 500 fog lights into the factory wiring. Works great!
Old Mar 18, 2011 | 08:03 AM
RAZDJK09's Avatar
Ok I will just have to make sure that fuse will blow first so that the Hella lights wont burn up the wiring.
Old Mar 18, 2011 | 08:20 AM
JK-Ford's Avatar
What Fuse?
Old Mar 18, 2011 | 10:50 AM
RAZDJK09's Avatar
Oh then I will put a new wire harness in, the last thing I need is to burn something up or worse yet burn it down to the ground. I thought maybe the factory lights would be fused in the fuse box. Oh well just that much more time I get to spend with the jeep and away from the wife.
Old Mar 18, 2011 | 01:36 PM
JK-Ford's Avatar
The lighting is monitored and protected by the computer. Most likely it would not let you burn anything up. But in many casas it has not let the system opperate.
Old Mar 18, 2011 | 05:39 PM
van7559's Avatar
what are the factory fog lights rated to watt wise or whatever?
Old Mar 18, 2011 | 05:44 PM
Corona Doug's Avatar
Let me know if you want to sell the lights... I just need the bulb... I have one that went out... went to the stealer... $45 for a friggin bulb!!! Ya gotta be kidding me!
