New Front Bumper - suggestions
Old Dec 1, 2008 | 04:35 PM
chevy51deluxe's Avatar
Lightbulb New Front Bumper - suggestions
After crumpling my stock bumper, I built one that I didnt do enough research on, so the tow hooks arent mounted well enough to really tug on, a winch is out, but there are some little 'd-ring mounts' that work great for tyin a canoe on top.
I have started on a second version using a dedicated winch plate (1/4") that ties to the stock mounting position, along with a laminated D-Ring mount that would mount the bumper also. This will utilize the stock fog lights too, and will have a hoop on it later.
Looking for anyone suggestions or nay-sayin too.
Thanks - Mike
here is a shot of the current/old one (version 1.0)
Old Dec 1, 2008 | 05:51 PM
tbfreebird's Avatar
Not sure about the new cad one as far as fog lights go. Guess you will angle the brackets for attachment so they shoot are straight but I think you might struggle with shadow from the bumper angles. Other than That - Looks great! I like the larger D-ring mounts!
Old Dec 1, 2008 | 06:03 PM
I was planning on using a 4" round to make a tube to butt up against the face of the light & use some sort of bracket like is on the on i made before.
I will try to get a better shot of the mounting area tomorrow.
That is where i have the most issues, is with mounting - not sure how the 'big guys' do it.
Old Dec 12, 2008 | 11:55 AM
IndianaJK's Avatar
Default Fog light cut outs
What size holes did you cut for the factory fog lights? Did you use a plasma cutter? Do you have ant specs on the mounting tabs for the lights?
I am making my own bumper now and would like to reuse the fog lights. I don't have a plasma cutter but could take it to a shop.
thanks for any information.
Old Dec 14, 2008 | 03:55 PM
Expedition One's Avatar
Former Vendor
On the new version, I would make sure that a winch will fit wile your in CAD. You may want to measure up your winch an make a quick drawing of it so you can see if there are any contact points were you may have interferance. I say that becuase of the blue gusits on each side of the winch mount look as though they could hit the gearbox and or the motor of a winch, depending on what winch your going with.
You may want to look at having the winch mount bolt into the frame at the back of the winch mount, in-between the the virtical box structures on each side of the frame that connect to the factory "bash-bar" (the ugly drop crossmember).
Other than that it looks like your on your way....
