New Gears
Old Dec 8, 2010 | 12:38 PM
acorkum's Avatar
Default New Gears
So I lifted my jeep 4" and put 35" tires on it. I am getting the superchips flashpaq to reprogram my speedo and other adjustments. Should I put a new gearing in it?? If so what gearing? I mostly use my jeep as a daily driver but do some off roading at places near my house but nothing to serious. Any ideas?
Old Dec 8, 2010 | 12:41 PM
AlexjeepVb's Avatar
2 or 4 door, auto or 6 speed?
Old Dec 8, 2010 | 12:49 PM
NH-JK's Avatar
Auto 5:13 auto rubicon 5:38
6 speed Id go 4:88 since it's a daily driver...
Tons of threads on this do a quick re-gear search. Good luck
Old Dec 8, 2010 | 12:50 PM
acorkum's Avatar
Its an automatic 4 door X
Old Dec 8, 2010 | 12:52 PM
nthinuf's Avatar
You go off-roading in your car? Why not just use the JK?
Open the FAQ's stickied to the top of this modified area...
Old Dec 8, 2010 | 02:21 PM
AlexjeepVb's Avatar
I think you would be happy with 5.13 gears , if you plan to go to 37s or wheel alot do 5.38
Old Dec 8, 2010 | 02:24 PM
JK.nick's Avatar
Auto: 5.13s is BEST. Do you drive on the highway often? If so then consider 4.88. That's what I'm having installed now
Old Dec 8, 2010 | 02:40 PM
nthinuf's Avatar
Open the faq's linked above and start plugging numbers into the chart.
5.13's are as low as you can go with your front D30.
(if you have any plans of swapping to a front D44, then wait and go with 5.38's)
Also, see page 3 here for some good info from planman that may help...
https://www.jk-forum.com/forums/show...itude%29/page3
There is quite a bit of evidence that this is incorrect. Higher rpm's will let you stay in OD without downshifting, which raises rpm's a lot higher, which reduces mpg's...
Old Dec 8, 2010 | 03:39 PM
JK.nick's Avatar
You are right, but it all depends on how you drive. I'm no gear expert, this is just what I was told. Excuse me if I'm completely wrong LOL
Old Dec 8, 2010 | 03:55 PM
hdrider's Avatar
Because of you D30 up front you can't go 5:38's so 5:13's it should be.
