New gears & bj's now pulls left
Old Jul 25, 2014 | 08:21 PM
meep97's Avatar
Default New gears & bj's now pulls left
I just picked my jeep up from the shop today after having new gears and ball joints installed and now the jeep pulls left pretty bad. I took a look underneath but couldn't see anything wrong. Any ideas of what it could be or do I need to take it back to them?
Old Jul 25, 2014 | 08:43 PM
Chefbrujo's Avatar
Need an alignmnet maybe?
Old Jul 26, 2014 | 07:06 AM
meep97's Avatar
Bump!
Old Jul 26, 2014 | 07:33 AM
bombout800's Avatar
If you didn't get an alignment while you were there, that could be the issue. If you had an alignment before with a bad ball joint it could be off enough to make it pull. How bad is the pull? Are both control arms the same lengths on each side? Tire pressure all the same? Axle centered?
Old Jul 26, 2014 | 09:26 AM
meep97's Avatar
The pull is pretty bad at highway speeds. Both control arms are the same length. Tire pressure is all the same. Axle is centered.
I'll have to check the alignment.
Old Jul 26, 2014 | 10:44 AM
meep97's Avatar
Just checked the toe and it's good.
Old Jul 26, 2014 | 10:57 AM
Rob 12B1P's Avatar
Trail grapplers pull left. If all your alighnment is good you can try dropping 1 or 2 pounds of air out of the front right tire.
Old Jul 26, 2014 | 02:32 PM
jeepmojo's Avatar
Default wonder if one of the ball joints
didn't seat right in the hole ?? My trail grapplers don't pull any direction btw maybe some do but mine have been on 20,000 miles steers straight . im almost afraid to add the gussets and ball joints now
Old Jul 26, 2014 | 02:40 PM
jaker t5's Avatar
What BJ some take awhile to break in
Old Jul 26, 2014 | 03:42 PM
planman's Avatar
Forum Tech Advisor
What he said.
Trail Grapplers pull left. Toyo MTs pull right.
You can offset the pull by either running a little less psi in the tire you need to drag a little, or you can run a gas charged steering stabilizer that is mounted in an orientation that pushes against the pull.
It's the tires. Nothing else...as long as your alignment is good.
