New issue
Old Nov 30, 2014 | 04:58 AM
fultonromero12's Avatar
Default New issue
I swear it seems this jeep all of a sudden is falling apart! I changed my rear brakes and rotors in attempt to solve a brake squealing issue. The old rotors were rusted in. After using a BFH to get them loose I noticed the inside has small amounts of fluid. I cleaned it up and finished up the job. Well today while dealing with a teraflex disintegrating puck issue I notice this. Guessing the axle seal is gone. I was wondering if by any chance the squeal and the drip could be associated? Any thoughts? I'm thinking of just replacing the whole axle shaft. Maybe a bent shaft is the cause of the squeal and also causing a drip since it's not seated correctly?
Old Nov 30, 2014 | 05:10 AM
GutlessPhred's Avatar
It could be axel shafts making the noise. Had same issue with my '07. Rear wheel was squeaky especially at certain speeds and got louder for a sec when pushed the brake then went away. Did a bunch of work to the brakes that didn't fix it just to find out I had a bent axel shaft.
Old Nov 30, 2014 | 05:30 AM
Thanks for the input.you are making me feel better about spending the $$ on the whole axle shaft instead of just replacing the seal. Did you replace it with a OEM or did you upgrade?
Sent from my iPad using JK-Forum
Old Nov 30, 2014 | 05:49 AM
I'd up grade to chromoly or something. I think there are some companies that are lifetime. If that is the problem I wouldn't do OEM.
Old Nov 30, 2014 | 05:52 AM
Jrutrubi11's Avatar
Mine always seems like it is falling apart..... Then I wash it and it drives like a new car.......
LOL
Old Nov 30, 2014 | 05:55 AM
Jrutrubi11's Avatar
It should be covered under warranty if you are under 100k.
Old Nov 30, 2014 | 03:30 PM
I wish I was one of the few chosen one with the awesome 100k mile warranty. Unfortunately I am the second owner. Only 65k on it and I'm stuck with the bill.
Old Nov 30, 2014 | 04:20 PM
nthinuf's Avatar
You can find some videos on youtube about checking for a bent rear axle flange. If you find that to be the problem, and you decide on aftermarket, check both Ten Factory and G2. They have 10-year warranties and both will cover bent flanges. You should be able to find G2 for around $300, and Ten Factory closer to the $350 range.
Old Nov 30, 2014 | 04:30 PM
I was just looking at both those on the web. Do you know if they come ready to install. With the bearings and seals pressed on?
Old Nov 30, 2014 | 05:48 PM
nthinuf's Avatar
It's been a while but I don't think either are pre-assembled. (Nitro's are, but not nearly as good a warranty) Pretty sure I saw that several of the site sponsors will assemble them before shipping if you ask. Worth a call or PM, anyway.
