New shocks......HELP
Old May 11, 2013 | 05:23 PM
Spencer4336's Avatar
Default New shocks......HELP
I have the 3.5" rough country lift kit but I am very unhappy with the ride its hard when I hit bumps and soft when I get on the brakes the whole nose of the jeep dips.
I am looking for a good on road ride because I only take my jeep rock crawling 2-3 times a month but I would like it to perform well rock crawling but mostly on road ride is more important any suggestions in what I should look at these are what I have been looking at as of right now. Any tips or suggestions would be great.
So I am looking at
-Bilstein 5100
-Rancho 9000xl
Or if I spend more money and buy the
-Tereflex tuned fox shocks
Thanks, Spencer
Old May 11, 2013 | 05:26 PM
Newfie's Avatar
I had the same issue with my RC 2.5 lift, upgraded to Bilstein 5100 and Bilstein dual stabs, awesome now, no more nose dives, and handling is amazing now.
Old May 11, 2013 | 05:40 PM
Thanks man it's good to know that I'm not the only one. I have the RC dual stabilizers do you think I should get the Bilsteins or just change out the shocks?
Old May 11, 2013 | 07:49 PM
Offroad_Elements's Avatar
Former Vendor
You won't notice much of a difference changing out the steering stabilizer(s); either Bilstein 5100 or Rancho RS9000XL are great choices.
The rough ride can also be the tire pressure... What PSI do you normally run?
Old May 11, 2013 | 08:00 PM
Im not sure right now but they are definitely not super high pressure because when are park on curbs you can the tire is squshed down i think it is the shocks because i have heard numerous reports of people having problems with RC's shocks.
Old May 11, 2013 | 09:33 PM
stagedtrip's Avatar
I love my rubicon express shocks (they are made by bilstein) think they were 78 bucks each
Old May 11, 2013 | 09:53 PM
jeeeep's Avatar
I really like the Bilstein 5100's but I hear the Rancho 7000 MT are good as well
Old May 12, 2013 | 04:15 AM
Newfie's Avatar
Default shocks
I just change the stabilizers shocks, and used the RC mounting kit I already had, and despite what others may say, I did see a big difference when I switched out all stabs & shocks. Make the switch, you will not regret it! The Jeep now rides firm, runs straight, and has no bounce, squishy floating feeling, no clunking, and feels like new! To say the least I am extremely satisfied with the upgrade. A friend of mine is also experiencing the same issues you have with his 3.5 on his 4 door and is in the process of switching to Bilsteins.
Old May 12, 2013 | 06:59 AM
Thanks for all your help everyone, I decided that I am going to go with the bilisteins.
Old May 12, 2013 | 07:13 AM
MFX's Avatar
MFX
A rough ride and nose dives when getting hard on the brakes is common when lifting a Jeep. A properly valved shock will help but to address the issues directly you'll need AEV front end geometry correction brackets for the lower control arms.
Check it out
JK Geometry Correction Front Control Arm Drop Brackets - JK Suspension - Suspension - Shop By Category
