New steering rod
Old Jul 24, 2008 | 06:49 AM
jkmud's Avatar
Default New steering rod
Drivetech shop's new 1.5'' x 1/4'' DOM steering rod with 1ton tie-rods. Try bending this ......
Old Jul 24, 2008 | 07:37 AM
Zylfrax791's Avatar
What diameter is it where it gets reduced down to the threaded portion?
Old Jul 24, 2008 | 07:38 AM
BLKRUBI's Avatar
Are they selling those and if so, how much?
Old Jul 24, 2008 | 04:17 PM
jkmud's Avatar
The DOM is 1 1/2'' in diameter and the wall is 1/4'' thick on passenger side they welded in threaded sleeve with jam nut to accept 1 ton dodge ram tie rod, the drivers side there is adjustable sleeve with same 1 ton tie rod, in this setup if something goes wrong ( unlikely ) all parts all available at any autoparts.
Old Jul 24, 2008 | 04:19 PM
jkmud's Avatar
Yes it is available, with the relocation bracket for your damper. The price is 450.00 plus shipping. If interested send me pm.
Old Jul 24, 2008 | 04:20 PM
ghostdancer308's Avatar
Default X2 on Price
Please!! Price quote!!
Old Jul 24, 2008 | 04:43 PM
jkmud's Avatar
[QUOTE=ghostdancer308;611190]Please!! Price quote!![/QUOT
450$ with damper relocation bracket
Old Jul 24, 2008 | 07:38 PM
tkob1060's Avatar
From: Hangin in the sunshine state....staging forum..
Rock Krawler makes HD ones also
tie rod 1 5/8ths
http://www.4wd.com/productdetails.aspx?partID=41379
and drag link
http://www.4wd.com/productdetails.aspx?partID=41378
1.5in thick and also takes 1ton ball joints, and its alot cheaper then 450
I believe Dr Dirty is running these now
Old Jul 24, 2008 | 08:17 PM
MONGO!'s Avatar
They look good, but seem a little pricey.
Old Jul 25, 2008 | 04:10 AM
jkmud's Avatar
Default Quality
1 5/8 solid rod bends like the stock one thats why is cheap, doesnt come with damper brackets and no tie rods, if you bend down under your jeep and see the geometry of your steering rod you will understand that strait bar has to have offset tierods to clear your diff. and other components, SO long offset tierods create weak points and full rod just doesn't meet DOM tubbing. If you looking at price only keep yours stock if you need hardcore this one is to be abused.
