View Poll Results: Which tire/rim combination?
16 inch rim w/ E Rated Duratracs
17.86%
17 inch rim w/ D Rated Duratacs
28.57%
16 inch rim w/ E Rated MT/R Kevlars
7.14%
17 inch rim w/ D Rated MT/R Kevlars
39.29%
16x8 with 4" backspace
17.86%
17x8 with 4.5" backspace
25.00%
17x9 with 4.75" backspace
21.43%
Multiple Choice Poll. Voters: 28. You may not vote on this poll
New Tire/Rims Poll
Old Jan 16, 2011 | 05:15 AM
Hawnted's Avatar
Default New Tire/Rims Poll
Wanted to hear what everyone had to say about what tires/rims I should get. Please chose a tire/rim size and a backspacing option.
This will be going on a 2011 Wrangler Unlimited. It is my daily driver, 50-60 miles per day mostly interstate. Ride quality is important. I have narrowed down my tires to 33 or 35 Duratracs or MT/Rs based on whether I go with the TF leveling kit or OME 2" Coil Lift. I have narrowed my wheel choices to Pro Comp 7069s or Black Rock 909b.
Old Jan 16, 2011 | 06:24 AM
AZJeeper's Avatar
Community Favorite
How about a little more info? Not enough here to help you.
What kind of wheeling do you do? Rock crawling? Mudding? Mild trails?
Is this a daily driver? Just an occasional venture off-road? Full-time off roader?
How big of tires are you considering? 32"? 33"? 35"? 37"? Bigger?
What kind of rims do you plan to put on? Beadlocks?
I would have different opinions/answers based on your intended use.
Old Jan 16, 2011 | 06:25 AM
sringer's Avatar
Definitely a great choice to get the bfg km2 I went with 35x12.50x17 and xd addicts matte black -12mm offset. Gives me between 4.5 and 4.7 backspacing. Great set up. 2.5 inch lift tf bb. No rubbing. It touched the factory aid dam so I ripped it out (plastic skid plate)
Old Jan 16, 2011 | 06:42 AM
Hawnted's Avatar
Mild Trails
Daily Driver. 50 Miles Per day on interstate.
33 or 35, have not decided between a leveling kit and a 2.5" coil lift.
My choice is down to pro comp 7069s or Black Rock 909b.
Answers posted above. Thanks
Old Jan 16, 2011 | 06:43 AM
Hawnted's Avatar
Originally Posted by TheDirtman
Why would you want to run an E load tire on a jeep? They are heavy, stiff, expensive, and designed to run at a high psi with a heavy load. A quality C is more than sufficient for a jeep.
I do not want to, but I like those 2 tires and that is all they offer in the 16 inch rims of my tire size. Did not know if it was a big enough deal to shift me to 17 inch rims. I prefer the more sidewall look of the 16, but if E rated tires are that big of a difference in ride quality I am going to go with 17s.
Old Jan 16, 2011 | 10:10 AM
nthinuf's Avatar
I chose everything. Decide on a lift and tire size at least. A poll that that many variables is pretty worthless...
Old Jan 16, 2011 | 11:18 AM
AZJeeper's Avatar
Community Favorite
Mild Trails
Since you will be doing mild trails and a lot of intestate driving, I would think the Duratracs would be a better choice than the MTRs. As the MTRs wear, they start to get a little noisier. They are definitely overkill for your intended use.
If you go with a bigger tire (35"), you'll need about 4.7" of backspace. A smaller, narrower tire requires a bit less. Get a rim wide enough to meet the manufacture's recommend wheel width. The MTRs should have a 8.5-11 inch wheel. Same with the 33" Duratracs.
I'd look at hub-centric rims or consider rings to help center the tire on the hub, especially for the amount of high-speed interstate driving you do.
No opinion on 16" vs 17". However, you'll probably have difficulty finding a 15" wheel that won't have brake clearance issues.
Good luck!
