New tires question
Old Mar 23, 2012 | 05:25 PM
swift6060's Avatar
Default New tires question
I just got my 35 and everything seems good except for a have low tire pressure light. Tire pressure is at 35 psi on all tires. ?????????
Old Mar 23, 2012 | 05:32 PM
Lsot's Avatar
Subscribed...
Old Mar 23, 2012 | 05:35 PM
Aggie83's Avatar
Spare also?
Old Mar 23, 2012 | 05:39 PM
B.S.'s Avatar
Originally Posted by Aggie83
Spare also?
Be sure to include the spare.
Old Mar 23, 2012 | 06:01 PM
bbrown626's Avatar
Your tire pressure is too high for a tire of that size. You should be under 30. Look at many other posts on here and consider performing a chalk test before you cause uneven wear.
Old Mar 23, 2012 | 06:08 PM
swift6060's Avatar
Plan on doing that chalk test tomorrow and the spare is at 35 psi. The spare tire is the stock tire and will changed out when I upgrade the bumpers. Its at 35 psi. Still not sure what would cause the pressure light stay on though. Maybe I am missing something really easy.
Old Mar 23, 2012 | 06:34 PM
HippieHunters's Avatar
Is the light solid or flashing?
Old Mar 23, 2012 | 06:36 PM
ScottW's Avatar
Possibly a bad TPMS valve. I had my light start coming on when tire pressure was fine and have turned it off with my superchips. I asked at Discount tire and they said they have something that can check the valves and find out if theres a bad one or a low battery.
Old Mar 23, 2012 | 06:39 PM
swift6060's Avatar
Thanks I will try looking at that
Old Mar 23, 2012 | 06:43 PM
Sparkplug's Avatar
Are you sure you got TPMs on all your new tires?
