new wheels
Old Mar 12, 2013 | 06:02 PM
bill9274's Avatar
Default new wheels
i am wondering what the pros and cons of 15" wheels are on our jk's. i can only find wheels that are 10" wide with 4" or less back spacing in 15". here are the wheels i am considering. i dont air down so the width is not in the debate.
Old Mar 12, 2013 | 06:08 PM
afpilot82's Avatar
JK-Forum Ambassador
Search my friend. There are plenty of threads about 15" wheels. The short of it is, some steelies rub, alloys don't.
Old Mar 12, 2013 | 06:12 PM
rays0852's Avatar
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=433263"/>
I actually just went from 18" Sahara wheels with 33s to 15" MB TKOs with 35" KM2s.
They clear the brake calipers. You will not be able to add a big brake kit. The only other consideration is aftermarket tie rod ends. If you end up wanting to go with a HD tie rod setup your options will be limited.
But my 35" KM2s ran me $240 a tire. That's like a sore d!ck.......you just can't beat it.
Old Mar 12, 2013 | 06:25 PM
bill9274's Avatar
thats good info thanks for the quick replies. so basically its a fitment issue i wont ever do bigger breaks may beef up the tie rods guess i will have to check clearence if i go with 15" wheels.
Old Mar 12, 2013 | 06:30 PM
Wandell's Avatar
Loved
The wheel specs you mentioned (10 inches wide with 4 inches or less backspacing) will also be a fitment issue. Most people run a 9 inch wide wheel with 4.5 inches of BS so a wheel that sticks out 1.5 inches or more will mean you will have to run a slightly smaller tire than most people with the same amount of lift.
Old Mar 12, 2013 | 07:17 PM
bill9274's Avatar
is it because they will rub the fenders when sway bars are disconnected. i plan on 3.5" lift with 35's
Old Mar 13, 2013 | 04:05 AM
Wandell's Avatar
Loved
That's a posibility, but you should probably be ok with a 3.5 inch lift. But, if you were running a 9 inch wheel and 4.5 inches of BS you could fit 37x12.50's with that much lift.
Old Mar 13, 2013 | 04:11 AM
Staytru06's Avatar
Idk but for such limitations with 15" rims I went with 17"s and only spent 30$ more a tire which adds up don't get me wrong but just seems like a benefit in the long run
Old Mar 13, 2013 | 04:59 AM
kjeeper10's Avatar
Vet Army
Balancing issues with a 35"
Aftermarket tie rod fitment
What wheel is that in a 10"?
