Newb axle question.
Old Jan 27, 2013 | 07:56 PM
Sgt Mack's Avatar
Default Newb axle question.
Can I bolt up the hubs of a Dana 44 front axle with out the shafts? I'm doing a rebuild and plan on dropping it off. I only need to roll the housing to the shop. So can I put on the knuckles, hubs and wheels on with out shafts or drive shafts and still be able to roll it 20 miles?
Old Jan 27, 2013 | 09:25 PM
5150cliff's Avatar
Sure you can. The axles are independent of the hub. The hub is held on by a large nut and if you remove the nut and the axle, the hub can remain.
Old Jan 27, 2013 | 09:29 PM
ronjenx's Avatar
The unit bearing is "self-retaining".
Look at this thread to see how it is made, and why it doesn't need the stub and nut as in the past.
https://www.jk-forum.com/forums/stoc...-study-124299/
Old Jan 28, 2013 | 07:09 AM
Sgt Mack's Avatar
That's exactly what I thought but wanted to confirm.
Now only if I could bust these ball joints out!!
