Newb lift question.
Hoping someone can help me. 2011 4dr jk sport auto. Bought OME spring/shock 2 inch kit. Was a little surprised it comes with just that...and some weird looking bracket thing....a few questions, what is the bracket thing for? Do I need a front or rear track bar? Do I need a steering stabilizer? If so on the prior 2questions, any suggestions? Btw, right now stock 17 rims and stock tires, will be going to 17 rims, and 33x12.5.
It's called the panhard extension bracket and bump stop kit...sorry I don't have a pic. But this link shows it....
ht tp://www.knowwhere2jeep.com/specials/old-man-emu-3-suspension-lift-for-jk-2-door-with-heavy-load.html
I just installed my OME kit with the panhard extension a few weeks ago. Without the panhard my rear axle was off center almost 3/4 of an inch. It was visible if you were looking for it. Installing it will center you rear axle under your body. The bump stops prevent the trac bar from hitting your shocks at full articulation. At least that's what the instructions said. Anyways it was very easy to install, took about an hour. You just need a drill and some basic hand tools.
