newbie asks for a little bb lift help
I have checked out the FAQ's in the newbie section and have found out a ton of great info for JK owners and newbies like me. but i have a suspention question that wasnt quite covered.
im going the budget route to fit 35's on my JK X, 2 door. i figure a 1in body lift, with the terra flex 2.5 inch kit is a good start. I just need to know if all those other components are needed, ie dropped pitman arm, adjustable sway bars, ect.
so to sum up, if I go the way of the 1in body, plus 2.5 in teraflex, what if any, extra components do you recomend. ill be using 16x8 wheels on 35x12.5 R16 Prnelli Jones DG
the 2.5 inch kit includes:
Front and Rear Coil Spacers
Front and Rear Bump Stops
Front and Rear Shock Adapters
Rear Sway Bar Links
Rear Brake Line Brackets
Rear Track Bar Bracket
thanks for the help, ill have pic of it when i return home from iraq, i bought my JK here and havent even seen it yet. cant wait to get it up on blocks and start workin on it.
Rear Sway Bar Links
Rear Sway Bar Links
Rear Sway Bar Links
Good idea,but I read as much on here,and talked to my local shop and I came up with the 3" Fabtech lift
Everything you need is in that kit I'm very impressed with all the extras the kit comes with.
Its not that cheap,but I didn't want to change the driving to much with the full suspension idea.This kit gave me as I measured 3" perfect all around.
This Fabtech kit clears the 35" tires with ease
The Jeep handles the same as stock,and handles off road just great
Hope this helps,you should check them out
http://www.quadratec.com/products/16119_050.htm
I love this Kit
I love this Kit
I don't think you are going to need a dropped pitman arm until you get up to 4" or more of lift. I have the 2.5" Skyjacker Boost on mine and am clearing 33's with A LOT of room left over. I'm sure 35's would ride awesome underneath right now. The body lift will give you a little extra tire room, but that's more of a personal thing...you won't need it. I didn't need any extra parts with my boost, but did opt for an aftermarket steering stabilizer to get the vibrations out that come with larger tires. Rides and handles AWESOME. I'm actually still using the same stock disco's, but am going to upgrade to JKS disco's in the very near future. I'm also still riding on stock rims and that will be changing soon too.
JK-Forum Founder
Rear Sway Bar Links
Rear Sway Bar Links
WOL pretty much summed it up. But if you are set on getting the extra height a body lift would give you, then take the money you would spend on the body lift, add it to the money you will spend on the BB and buy the Teraflex 2.5" coil spring lift. You can get it from northridge for $600 w/shocks or $440 w/shock adapters and free shipping.
ok thanks for all the info, it did help allot, i think ill save just a little extra and not rush it, get all the right parts. good lookin jks yall got there too.
