Newbie backspacing question
Old Jan 25, 2013 | 08:47 AM
coliniski's Avatar
Default Newbie backspacing question
The lift that I am looking at is a Teraflex 2.5" lift from quadratec. While reading the description I noticed that it recommends that you use a wheel with a 4.5 backspacing. The wheels that I want to put on have a 4 7/16 backspacing. Will this pose a problem? If at all how will it affect the ride? I have a 2012 Sahara unlimited. Thank you in advance
Old Jan 25, 2013 | 09:42 AM
Overnite's Avatar
If I am reading your post correctly, 4 inches and 7/16ths of a inch. This is just 1/16ths from being a half inch if the full inch is broke down to 16ths. So to me, that's a 4.5 inch back space. You're good to go my man.
Old Jan 25, 2013 | 09:46 AM
SpicedCrusher's Avatar
I'm running the 2.5" from TeraFlex with 7069 wheels that have 4.75" of BS. No rubbing at all.
Old Jan 25, 2013 | 09:49 AM
afpilot82's Avatar
JK-Forum Ambassador
You'll be fine, those come out to 4.44", not enough to make any difference.
Old Jan 25, 2013 | 09:52 AM
kgonzalez's Avatar
You'll be fine. If you were running over 4.5, you might have minor rubbing, but you're gonna be just under 4.5. Post pics after!!
Old Jan 25, 2013 | 12:45 PM
Ironhead920's Avatar
Pull out a tape measure. Count 7 of those tiny notches. That's 7/16. 8 is 8/16= an half inch. I'm pretty sure your good. 1/16 is TINY
Old Jan 25, 2013 | 03:10 PM
Gman*2007's Avatar
Welcome to the forum.
Old Jan 27, 2013 | 09:04 AM
coliniski's Avatar
How Do you like the lift, any problems
Old Jan 27, 2013 | 09:13 AM
GiggityGiggity's Avatar
as others have said, you're good. especially if you plan to run a wider tire, greater than 11" wide you have plenty of room with that offset. You can actually run a 5.71" backspace with a 11" tire on a 9" wide wheel with no problem either. How wide are your wheels?
1010tires.com has a wheel offset calculator if you play around with it. Factory wheels are 18x7.5 with a 6.25" offset. that's your base line.
Old Jan 29, 2013 | 10:09 AM
coliniski's Avatar
the wheels are 8"
