Newbie-Help
Old Mar 28, 2010 | 06:47 AM
MAGRACER's Avatar
Default Newbie-Help
I am not going off road at all. Plan on 35x12s. Iam torn between teraflex 3" kit. What about Rustys kits. Price is great for 3.5 kit. I like that it has adj trac bars. Could upgrade to Bilstein shocks later, using thier shocks. I am leaning toward this kit., I know all the good things I here about Teraflex. Tight budget.
I emphasize street use only.
Old Mar 28, 2010 | 07:24 AM
RevyJKU08's Avatar
Try a 2.5 TF coil lift or OME HD coil springs these kits will fit 35's easily!
Here is my OME HD coil springs but with 33x12.50's and it has netted me over 3" of lift! You can see it will fit 35's even with a winch and bumper.
Some things you may need is rear links, adj track bars, new shocks and even consider front LCA's
Old Mar 28, 2010 | 07:41 AM
K9JKdriver's Avatar
go w/ the 2.5 Tera flex BB....easy install maintain stock ride
Old Mar 28, 2010 | 07:48 AM
NewfieScreech's Avatar
A Jeep with a TF kit and 35's that will not be used for offroading...
That's a sexy lift and tires for street only... I hope you change your mind down the road and take her offroad for some abuse!
I'd look into gears if I were you...will help with highway use. I would say 5.13's for an automatic and 4.10's or 4.56's for a 6 speed. some people might disagree though....
