Newbie mod help
Old May 26, 2013 | 05:17 AM
jhoot6's Avatar
Default Newbie mod help
Any great jeep mechanics in Boston area. I can't easily get to Elias in Townsend, MA plus he is only open mon-thurs. need help installing KC driving and long range light that turn off with engine even if switch is left on, relocate vac pump and off camber light bar. I am a newbie with 2013 rubi unlimited and trying learn so forgive ignorance
Old May 26, 2013 | 10:31 AM
Gman*2007's Avatar
It's probably going to be hard to find someone this weekend, being a holiday & all. Welcome to the forum.
Old May 26, 2013 | 10:38 AM
karls's Avatar
Your light issue is easy, put a relay in there and trace back the 'switch' wire to one side of the switch and come out of the other side of the switch hooked to your "switched power" source (key switched cig lighter works great)
I've "relocated" a vac pump with a grinder to adjust the bracket and then simply zip tie it until the $12 bracket comes in.
Light bar should be cake for you too- bolt it up.
You don't need a 'jeep' mechanic for most of it, I'm sure anyone can hook things up with directions.
Old May 26, 2013 | 06:17 PM
Jlagross's Avatar
Be careful with the Kcs, I have em and already got asked about them by a cop in the area (Burlington ma area) . Had to argue that a rock guard was a form of a cover. He must not have had a legit reason to pull me over if he was trying so hard to find something wrong haha. He gave me a warning for the lights and tires out past the flares, fricken stupid
Old May 26, 2013 | 06:36 PM
Kaptain17's Avatar
Burlington cops suck! Same with Billerica!
Old May 27, 2013 | 04:07 AM
Jlagross's Avatar
Haha funny. I'm actually from Billerica. Send me a pm we'll get together sometime.
Old May 27, 2013 | 06:18 AM
celticmoon's Avatar
OP... What better way to learn how things work on your Jeep than doing it yourself and making mistakes, then fixing them? Go for it, you will find its not all that hard to do, and you will feel the pride if knowing accomplished it.
Starting to think I should stay north of the border here in Nashua. It's bad enough your governor shut down all of the roads in the state over a little snow a few months ago. (Still went out at the height that night to pick up a nurse after calling the PDs in each town along the way to Newburyport to get an OK)
If it's a driving light, covers shouldn't even be an issue. If it was a headlight, go ahead and make restrictions. Something that's auxiliary and most cars don't even have?
Old May 27, 2013 | 09:49 AM
Jlagross's Avatar
What's your reason to having them only on when the jeeps on?
I wired mine so I could have them on wenever , and honestly I've used them alot while the vehicle is off ( camping mostly )
