Newbie needs some help with TF 2.5 BB
One last update...
I removed the rear sway bar links last night, hit a couple bumps to test, and the noise is gone. I had the links mounted on the inside of the sway bar and the inside of the axle mount, as many have said to do. Any ideas or suggestions as to why they were making all that racket?
Also, to be honest, I really can't tell any difference in driveabilty with the links off. Surface streets and freeway and no difference in feel. (Haven't tried off road) I've read the post talking about pros and cons of running without rear sway bar, and if I can get the noise to stop with the links on, that's the way I'll go. The plan is to re-install tonight and test again. Anybody got any tips??
If you carry any speed into a corner you'll get tippy without those rear links.
Maybe the bolts are hitting the frame or brake lines, I think I have some minor rubbing on mine I still need to fix.
