Newbie wheel question
Old Jun 15, 2014 | 04:40 PM
jHaru's Avatar
Default Newbie wheel question
I am looking into getting aftermarket wheels for my jk. Currently it has 255/70R18 sahara wheels and I was looking to get 275/65R18 wheels. Thing is I feel like I'm wasting money to buy a fifth wheel.
According to a tire calculator... The stock diameter is 32.06 and circumference 100.704. The new tire would be 32.07 diameter and 100.766 for the circumference.
Are the differences so small it's negligible. Then I can I use the stock as a spare and put a cover on it or will I shred apart my differential if use it as a spare.
Old Jun 15, 2014 | 04:42 PM
jHaru's Avatar
I imagine its no good bc after thousands if revolutions it's no longer negligible.
Old Jun 15, 2014 | 05:47 PM
bludevlsi's Avatar
You will be just fine using stock spare if you need to.
Old Jun 15, 2014 | 07:35 PM
TheDirtman's Avatar
Buy the fifth wheel (spare) and rotate it in with the tire rotation and you will get 20% more life from a set vs just doing 4. I would go with a 17" wheel as well as tires are cheaper and you will have far more choices.
Old Jun 15, 2014 | 07:38 PM
JumpingInFire's Avatar
It is not clear if you are buying wheels, tires, or both.
Old Jun 16, 2014 | 02:17 AM
jHaru's Avatar
Wheels and tires
Old Jun 16, 2014 | 04:09 AM
GetLost's Avatar
X2 on 17"wheels & the tire sidewalls are usually taller.(more bite, more depth before a wheel is hit)
