next upgrade
While i'm waiting on the closing for my house, I'm looking for inexpensive mods while I have free labor and use of a shop. best steering stablizer and relocation kit? It will need to be compatible with a Rock Krawler long arm lift. what setup should I go with?
aRe there any relo kits to stay away from or do they all do pretty much the same thing? I noticed that my steering stablizer got twisted this weekend so the braket is actually twisted all the way around the tie rod. Just coincidence that I'm in the market for a relo bracket and stablizer upgrade?
Is that compatible with the RockKrawler HD tie rod (larger in diameter) or can I re-use the larger ubolts supplied with the tie rod for use with the original stabilizer?
and where is the cheapest place to get the bilstien stablizer and relo kit mentioned?
I ordered my bilstein stabilizer from Gus at offroad warehouse and the stabilizer from Brett at Jeep SWAG/Dominion Offroad (jeepswag.com)
ouch! over 200 for just the stablizer! I found the teraflex for around 60. Can I get the bilstein for close to that? Bracket looks to run around 30 bucks but I havent found any place that has both as a kit. It would be nice to stay under 100. It looks like the swag kit re-used the same end that's on my tie rod right now which re-uses the provided larger u-bolts.
Jeep SWAG sells their relocation bracket and their own stabilizer for $100
screaming lizard has the relo bracket and the teraflex for around 85 so the bilstien and bracket should able to be done as a kit for 100.
