Nitto ballance issue
Old Mar 23, 2010 | 05:10 PM
o7jk's Avatar
Default Nitto ballance issue
I bought the Nitto Terra Grapplers a couple weeks ago. it seemed as if the balance was off so i had NTB rebalance my drivers side front tire. the tire was way out of balance. I watched them balance the tire, it took almost 5.5oz the dynamic balance machine showed it to be balance fine but now it seems even worse. can anyone think of anything that would cause this wobble (not DW i know what that is)
Old Mar 23, 2010 | 05:18 PM
thissideup's Avatar
Get a white paint pen and place a small mark on the rim and tire at the lip. See if the tire is slipping on the rim. Someone I knew fought with this for a loooong time. Stupid tire would rotate on the rim knocking the balance all to piss.
Old Mar 23, 2010 | 05:20 PM
thissideup's Avatar
By the way I have the same tires and they have been good. The only thing wrong with them is that they are 315's not 37's
Old Mar 23, 2010 | 05:40 PM
Evolution's Avatar
Sponsoring Vendor
I would recommend Trying a different person balancing your tires .
There is a reason if you ad weight to a Rim and the vibration gets worse, It simple the wheel didn't need weight in that spot.The weight was added to the wheel in the wrong spot.
Old Mar 23, 2010 | 08:40 PM
woolybully's Avatar
Default Nitto
i have the Nitto Mud Grapplers and they have been as close to perfect as I have seen in an off road tire. I had 35" on my TJ and just got my 37"'s for my new JK 4 door due to be installed next Monday.
