Nitto Mud Grapplers PSI
Hey everyone-
I just picked up a set of 35 inch mud grapplers off craigslist and was wondering what psi everyone is running in them. They are E rated, so I guess that is why the sidewall is recommending 45 psi. I think this is a little steep, but wanted to check with all of you. Right now it seems a little bouncy. They are 35 12.5 18's.
Thanks
Thanks
I run my 33in Mud Grapplers (same E rating) at 37 psi. They ride a little hard, but I have 32,000 miles on mine and have only lost 3mm out of the original 14mm tread depth with even wear. I also wheel hard 3-4 times a year. Make sure you rotate them every 3-5,000 miles and they will last a good long time.
check this out....
https://www.jk-forum.com/forums/modified-jk-tech-2/mud-grappler-tire-pressure-78802/
dang l3itch you're fast
Do you mean posting a response or going down a steep hill?
Hey everyone-
Thanks
Thanks
both!
anywhooo... JKJosh the link in my last post will bring you to your answers. the sidewall reading is no where near what you should be running... infact its WAY over. by running that psi you should be experiencing a knobby ride... bring your 35s down to 28psi and your ride will smooth right out.
