No control arms for new driveshaft???
Old Mar 24, 2009 | 11:28 AM
officer_vince's Avatar
Default No control arms for new driveshaft???
Talking to one of the tech's at my local Jeep shop and he seems to think I can run a double-cardann (ie tom woods) rear driveshaft without needing upper control arms in the rear.....any input on this?
Old Mar 24, 2009 | 11:44 AM
bigbluejk's Avatar
how will adjust for correct pinion angle? Or is he just hoping it will be ok?
Old Mar 24, 2009 | 11:47 AM
rab986's Avatar
What he said... if the pinion angle is not correct then the drive shaft will just be a cover.
Old Mar 24, 2009 | 11:48 AM
wayoflife's Avatar
JK-Forum Founder
your local jeep tech is an idiot. with a double cardin drive shaft, you NEED to have your rear pinion to be in line with the drive shaft. the only way you can do this is with a set of adjustable upper control arms. if you do not set your pinion angle, you will have vibrations and enough so to screw up all kinds of things like your output shaft and pinion seals or your u-joints.
Old Mar 24, 2009 | 12:50 PM
Thats what I thought I knew in the first place but figured if he was telling me the opposite then I may as well check it out.
Bad advice no doubt.
Old Mar 24, 2009 | 12:53 PM
bigbluejk's Avatar
I think I would find someone else to work on my Jeep.
Old Mar 24, 2009 | 01:32 PM
Northridge4x4's Avatar
Sponsoring Vendor
I agree! but it is hard to call him a jeep "tech" after that advice!
David
