No Doors Mirror Option
Old Mar 22, 2008 | 08:31 PM
CLACKEY(_!_)'s Avatar
Default No Doors Mirror Option
So I took my doors off for the firsrt time EVER. I went to PepBoys to get a mirror. I found this little gem and thought I'd share. The bolt on the mirror is the same thread size as the bolts that bolt into the pillar. I simply pulled out the top pillar bolt and screwed in the mirror.
The mirror needed to be pulled a little and bent so I could get it to adjust correctly for me. I bolted on the passenger side also though I can't see crap yet. I'm working on it. I'll update later and give a full write up.
Yes, I plan to paint them BLACK
The mirrors were about $15 each.
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Old Mar 22, 2008 | 08:32 PM
Aolec's Avatar
Nice find... might have to check that out. Hows the driver mirror work?
Old Mar 22, 2008 | 08:40 PM
Once I pulled on it and bent the housing slightly I got it to adjust perfectly. I like it cuz it's big. (same size as the stock mirror).
Old Mar 22, 2008 | 08:45 PM
dr.dirty's Avatar
looking good man you still want those shackles
Old Mar 22, 2008 | 08:59 PM
Whats Next's Avatar
NICE FIND , AND PROBABLY ONLY ABOUT A 3 OR 4 MIN INSTALL
Old Mar 22, 2008 | 09:03 PM
Yep it was pretty quick. I still need to figure out the passenger side. It needs to come WAY in. I might put some heat on it and try to get it to bend the housing a little to get it to work.
Old Mar 22, 2008 | 09:21 PM
Whats Next's Avatar
GOOD LUCK, HOPE IT COOPERATES.
Old Mar 23, 2008 | 12:21 AM
Foo's Avatar
Foo
I've ordered 2 of these. Autozone, just search for Euro Mirror.
On some forum I've seen JK people using these. Nice cheap option.
http://www.autozone.com/R,NONAPP3374...ductDetail.htm
Old Mar 23, 2008 | 05:49 AM
2K1TJ's Avatar
Looks good!
Old Mar 23, 2008 | 07:31 AM
http://www.autozone.com/R,NONAPP3374/store,877/shopping/accessoryProductDetail.htm
Those look like they
belong on a Rice Burner.
