No instructions or template
Old Aug 10, 2009 | 05:58 PM
NonHyphenated American's Avatar
Default No instructions or template
My TF spring lift and steering stabilizer came in today and I will install this weekend. No instructions came with stabalizer and no template for track bar. Where can I get both?
Old Aug 10, 2009 | 06:02 PM
falconfixer's Avatar
You could probably give Joe a call at Teraflex.
Old Aug 10, 2009 | 10:09 PM
nthinuf's Avatar
Look at any of the write-ups from members of this site...
https://www.jk-forum.com/forums/show...7&postcount=10
It doesn't have to be the 'exact' lift you have for the write-ups to help out. For the most part, a coil lift is a coil lift, they all generally use the same types of parts and take the same steps. You're also more likely to get some better feedback of any problem areas this way.
Old Aug 11, 2009 | 06:10 AM
TeraFlex's Avatar
Sponsoring Manufacturer
PM your email address to me. I know we just finished instructions on the stabilizer. With lift kit did you get?
Old Aug 12, 2009 | 05:37 AM
Littlejon's Avatar
I am assuming you ended up with the Tera 2.5 kit, and if you look online at the budget boost instructions they have the template for the TB bracket. This is where I pulled mine from since it wasn't attached to the 2.5" spring lift instructions at that time.
