No rear sway bar
Old Mar 6, 2008 | 08:51 PM
Big D2's Avatar
Default No rear sway bar
Anyone running without the rear sway bar? How is the performance?
Old Mar 6, 2008 | 10:47 PM
derekls's Avatar
I havent heard of anyone running without the rear
The rear is alot more flexible then the front so dont think there is no reason to remove it
Old Mar 6, 2008 | 11:24 PM
yellowjeeper85's Avatar
I did this on my TJ... it was cool on the TJ, but i think JK's esp system would have a fit with that much body roll,
Old Mar 7, 2008 | 12:32 AM
Phishjeep's Avatar
Well, one guy was running without his rear sway bar. And he flipped his JK on a trail ride. However, He says it wasn't related. But I don't know of anyone else doing it. I would like to know more, though. Any others runnning sans rear sway?
Old Mar 7, 2008 | 06:09 AM
Eracer76's Avatar
It doesnt sound like a good idea to me...
You need to have something to keep the Jeep from leaning over when on off camber hills.
Old Mar 7, 2008 | 07:21 AM
simon's Avatar
I believe Kenny from River Raider Snorkels runs without the rear swaybar. Not 100% positive, but am pretty sure.
Old Mar 7, 2008 | 07:24 AM
Big D2's Avatar
The reason I want to remove it:
First of, that sway bar is fairly thin. But nonetheless it is designed to work with the front sway bar to balance the car. In a rear wheel drive or solid axel vehicule the biggest weight shift occurs in the front. Hence, the huge thick sway bar up front. If I was designing the suspension, I would put higher rate springs on all corners (compression might suffer a little, always a compromise I guess) , a bigger front sway an no rear.
I've had both sway bars off on my Liberty. Drove like that the whole summer (not the first vehicule I had off with sways). Offroad is was amazing. Just like a trophy truck. The front end stayed level as each of the wheels worked independently. The back end drove over the obstacles at speed as opposed to boucing over them sometimes. Mind you the rear sway bas a lot bigger than on the Liberty.
On road handling was ok too. Yes it does lean more and yes it's a truck so you don't drive it like a racecar. I found that once you approach the limits of the lean you would actually feel that it is coming up to it's limits. With both sways, you would stay level until you reach a point where it snaps and breaks loose. If you ever want to see how this works do a wet skid pad test to give you a feel of what's happening.
Almost forgot...I want to move the rear sway links to the front since they are a little bit longer to compensate for the RC BB lift.
Old Mar 7, 2008 | 07:37 AM
JacksJeep's Avatar
Yeah, I have the rear sway bar off my Liberty too. It does help improve articulation. What we need is brave soul to take his off his JK and see how it drives. Any takers? It may not significantly improve articulation since the JK was designed as a more hard core wheeler than the kj was.
Old Mar 7, 2008 | 07:47 AM
Big D2's Avatar
I'm taking it off as soon as we stop getting it dumped on with snow here.
Worst winter in 60 yrs. Another storm coming for the weekend. Yikes. Time to hit the trails.
Old Mar 7, 2008 | 08:08 AM
Big D2's Avatar
Ooops. I keep forgetting the ESP. Someone mentioned it on another board. With the sway off (on road) the ESP should still do it's job?
