noise at higher acceleration??
Hello,
I am having a noise that does not seem to go away....it does not happen at idle and it gets louder and louder at higher speeds...my initial thought is a wheel bearing (have stock rubicon wheels) but i have no clue....it gets pretty loud around 40mph and sounds kind of like a "baseball card in the bike spoke" after your bike is going faster....it just sounds like a ton of road noise and i cant tell if its the wheel, the tires (25000 miles on stock bf goodrich mt--~50% tread life) or if there's another problem that i don't know about...i have a 2.5" teraflex coil lift with spidertrax wheel spacers and teraflex lower control arms in the front and superchips flashpaq.
does anyone have any suggestions?? i have done tons of research on wheel bearings, pinion bearings, alignment, etc...and other than this really annoying noise the jeep drives totally fine. i have the 6 speed 2 door
It seems like it is coming from the front...as i approach 40mph it starts to get louder (unnaturally louder--not road noise loud)....sometimes its not too bad and sometimes it makes a "tick tick tick tick" but very fast....it sounds kinda like a train coming to a stop sometimes with "tick tick tick tick" at a very fast rate...i have no clue what it is....i'm going to take it in to the dealer in a few weeks but i don't want them to give me any crap if it is a wheel bearing becasue i have spidertrax spacers
So I took my jeep to firestone to see if they can change my oil and do the 19.95$ total inspection of the jeep for something wrong with the wheel bearings or suspension or just loose bolts somewhere that are banging back and forth. they said that it was literally just the tires that are "cupping" due to possible overinflation. I saw the tread was definitely cupping, but I generally keep my tires around 40psi for daily driving....is this too high? I aired them down to closer to 30psi and now my TPMS light is on
-I really don't know how cupped tires can be that obnoxiously loud, but they are. Since airing down 8-10psi the tires have gotten quieter...i can still hear the "metal banging around" noise but it is less frequent and not as loud as before...
The tires are pretty worn down and I'm getting 35" tires within the next month or so...hopefully the noise is totally gone when i get new tires.
Tire pressure should be around 34 according to the door placard. 40 is deff high and 30 is low for the TPMS. Cupping does suck. Actual cause is improper alignment and/or rare tire rotations
