Noob pinion angle question with pic
Old Mar 28, 2017 | 10:03 AM
raymo's Avatar
Default Noob pinion angle question with pic
My wife has a 2015 Jeep 4dr and we've put a 4 in lift and 35s on it. The kit is the Rough Country 4in x series and it has upper and lower adjustable control arms at each corner. The control arm lengths were set to spec but it looks to me like the rear pinion is pointing too high. I've read a little about axle wrap on acceleration that might move the pinion down but I'm clueless. Do I need to adjust this?
Old Mar 28, 2017 | 10:15 AM
Da20captain's Avatar
I agree it looks too high.
Old Mar 28, 2017 | 10:29 AM
ronjenx's Avatar
No need to accept that angle when you have adjustable control arms. What's it look like sitting on the tires?
Since you mentioned axle wrap... That would tend to raise the pinion, and be more of a factor on leaf springs.
Old Mar 28, 2017 | 10:38 AM
jchappies's Avatar
Driveline and pinion angle offset should be within 3degrees of each other. With adjustable you should be able to get to 0-1degree easy
Old Mar 28, 2017 | 10:49 AM
resharp001's Avatar
Loved
Community Favorite
That picture is a little misleading as it's jacked up. As Ronjenx asked, what does it look like when it's sitting under load? That rear DS and pinion should be fairly close to a straight line in the rear.
Old Mar 28, 2017 | 05:11 PM
raymo's Avatar
Thanks everyone for the input. The Jeep is jacked up in the picture but it is supported by jackstands under the axle tubes so it represents pretty much how it sits on the ground. I'm going to pick up an angle finder and see if I can't dial it in better
Old Mar 28, 2017 | 05:55 PM
Biginboca's Avatar
Since you have a factory Driveshaft that pinion is too high and you might even have vibrations at high speed. For a factory shaft the pinion angles are forgiving but should still be somewhere between pointing level with the ground and pointing straight at the transfer case, yours is pointing above the transfer case. Aftermarket double cardan shafts need to point directly at the transfer case...
