Noob question...
Old Sep 23, 2012 | 07:41 AM
DannyMalkin's Avatar
Default Noob question...
Can someone explain what exactly is involved in a lift kit? I want to get the evo mfg coilover but it not a kit, so would it have to get another manufacturers lift then replace the coils?
Old Sep 23, 2012 | 10:53 AM
Gman*2007's Avatar
It all depends on how your planning to drive, offroad, trails, rocks, etc. If your just wanting to put bigger tires on, all you need is a leveling kit or coil spring spacers.
Old Sep 23, 2012 | 11:25 AM
Robar's Avatar
Off Road Evolution makes or sells everything you need for a coilover lift. Just give them a call, they are there to help answer questions.
Old Sep 24, 2012 | 08:22 AM
EVO MFG's Avatar
Sponsoring Manufacturer
Are you talking about Coilovers or a coil and spring lift?
We do have kits for the Coil and spring lift, the EVO Enforcer kit, available in 3" or 4"
EVO MFG: EVO Enforcer Kit w/ Plush Springs, JK 35" Tire Package
Old Sep 24, 2012 | 06:21 PM
I was looking at the bolt-on coilover kit. Does it come with everything for a lift or just the actual coilover? (sorry if I sound like an idiot, I'm no expert)
Old Sep 25, 2012 | 08:10 AM
EVO MFG's Avatar
The kit comes with everything you need to install the coilovers, bump stops, coilover brackets, brakelines, swaybar links.
What you do need to add is lower adjustable front control arms, and a draglink flip kit, front driveshaft. Please give me a call if you need to talk it over.
