NR Bolt Kit Install Question
Old Oct 29, 2013 | 04:58 PM
NCRUBI2012's Avatar
Default NR Bolt Kit Install Question
Finally getting around to installing this. Do I need to jack up Jeep or can I just do on ground? Trackbars I know I can do but what about LCA? Do they need weight off to replace but not tighten and full weight to torque
TIA
Old Oct 29, 2013 | 05:20 PM
Invest2m4's Avatar
No, do it on the ground. One bolt at a time though. I installed the same kit and there were a couple holes where I needed a little leverage (someone pushing the axle or used a pry bar).
Old Oct 29, 2013 | 05:27 PM
MMXJKU's Avatar
Slowly lifting the pinion with a floor jack will rotate the axle to help in lining up the holes. Like said before do one bolt at a time. Be sure you have a torque wrench.
