O/D off equivalent to Re-gear
Old Apr 13, 2017 | 07:02 AM
silverbullet88's Avatar
Originally Posted by jedg
You're missing part of the picture. You're only looking at your highest gear and in 2WD. You haven't considered the final gear ratio while in the other gears as well as in 4WD.
Right. The 4-1 rubicon case is sweet and still works well with my setup. What do you mean the other gears though? In 2wd?
I just always imagined re gearing and it holding 4th.
Old Apr 13, 2017 | 07:59 AM
jchappies's Avatar
Awesome calculator for Jeep
Gear Ratio RPM Chart Calculator
Old Apr 13, 2017 | 10:44 AM
Mike H.'s Avatar
go to this website Gear Ratio Calculator
in 1 column enter 4.10's, in the other enter 5.13's and compare the 2 side by side.
I used 42RLE for transmission, NVG241or for t-case and 33.75" tire for 35's.
With 5.13's, in 3rd gear, 60mph you're going to be sitting at ~3050rpms, 70mph will be at ~3600rpms.
With 4.10's, in 3rd gear, 60mph you're going to be sitting at ~2450rpms, 70mph will be at ~2850rpms.
You say it is dropping into 2nd gear now... sooo...
With 4.10's, in 2rd gear, 60mph you're going to be sitting at ~3850rpms, 70mph will be at ~4500rpms.
Since under load the 3.8 is going to work best between 3500-4500rpm (TQ peak)...
I'm betting that you will go up moderate/typical grades in 3rd at 70mph with 5.13's(3600rpm) that currently with with 4.10's will be asking for 2nd gear to do 60mph(3850rpms). I'm also betting it will go up lots of slight grades in 4th at 2400rpm where currently it's looking for 3rd and 2850rpms.
Good luck.
Old Apr 14, 2017 | 08:04 AM
Originally Posted by Mike H.
go to this website Gear Ratio Calculator in 1 column enter 4.10's, in the other enter 5.13's and compare the 2 side by side. I used 42RLE for transmission, NVG241or for t-case and 33.75" tire for 35's. With 5.13's, in 3rd gear, 60mph you're going to be sitting at ~3050rpms, 70mph will be at ~3600rpms. With 4.10's, in 3rd gear, 60mph you're going to be sitting at ~2450rpms, 70mph will be at ~2850rpms. You say it is dropping into 2nd gear now... sooo... With 4.10's, in 2rd gear, 60mph you're going to be sitting at ~3850rpms, 70mph will be at ~4500rpms. Since under load the 3.8 is going to work best between 3500-4500rpm (TQ peak)... I'm betting that you will go up moderate/typical grades in 3rd at 70mph with 5.13's(3600rpm) that currently with with 4.10's will be asking for 2nd gear to do 60mph(3850rpms). I'm also betting it will go up lots of slight grades in 4th at 2400rpm where currently it's looking for 3rd and 2850rpms. Good luck.
Thanks that's a lot of good info. Exactly what I was thinking it would be around. So why re-gear? You'll get 4th back for the most part but that's about it. And some low end acceleration. If the torque converter can lock in 3rd or 4th and keep the heat down.
I just need more HP!!!!
Old Apr 15, 2017 | 08:04 AM
TheDirtman's Avatar
any time you go up a steep hill your transmission is going to shift into a lower gear. With your current set up I would just leave it but if you go to an actual 35"+ tire a re-gear should be considered. Not having proper gears puts stress on the entire drivetrain including the driveshafts.
Old Apr 15, 2017 | 08:53 AM
Yeah that's a good point. 35" that actually measure that while mounted?
Old Apr 15, 2017 | 09:01 AM
TheDirtman's Avatar
Yes, I try and use actual size since it varies so much between different manufacturers.
Old Apr 16, 2017 | 11:58 AM
Wandell's Avatar
Loved
I know ours drives much better with overdrive off running 35's and 3.73 gears. I'm sure not as good as with lower gears, but much better than with overdrive on.
Old Apr 16, 2017 | 09:26 PM
Yeah. It's just a dog. Before I put anymore money into the 2dr I'm going to wait to see what the jl is like. If I don't like that then a 4 door jk it will be.
Either way it'll be a 6 speed
Old Apr 18, 2017 | 07:38 AM
GunDude's Avatar
Originally Posted by silverbullet88
Yeah. It's just a dog. Before I put anymore money into the 2dr I'm going to wait to see what the jl is like. If I don't like that then a 4 door jk it will be. Either way it'll be a 6 speed
3.73's and O.D off was ok. But, ended up regearing to 5.13's, because I wanted Trutrac's front and rear. If, it is power you want, then drop coin on a V8 and not another dog. Glad, I do not live where there are big mountains!
